Welcome to!
Old 05-19-2009, 04:15 PM   #1
uzi577's Avatar
idle is to high. Smoke test
The idle is 950rpm it is maybe 75 rpms higher that normal,also I am getting 1189, 1188 codes talk to Active, Craig said that I have a small vacume leak.
Correct me if I am wrong but smoke test will be the most cost efficent way to detect and neutralize the problem, if yes where in north york/ vaughan or mississuga area can I get it gone?
uzi577 is offline   Reply With Quote
Old 05-20-2009, 02:28 AM   #2
Hooked on Boost
PedroBMW's Avatar
Any Mechanic can find your vacuum leak.
Old 06-09-2009, 09:07 AM   #3
uzi577's Avatar
Codes 1188, 1189
Replaces O2 senser both on banks one and two. got both codes back, Drove with check engine light for 2-3 days, today started the car in the morning the check engine light is gone, connected my OBD reader the codes are still there. WTF?
Old 06-09-2009, 11:17 AM   #4
If the codes are no longer faulting, the reader will show that the ECU still has a history of the codes.
1188, 1189, code
