05-28-2009, 02:23 PM
#1
Car: wish to drive bimmer
failed e-brake replacement of shoes
so I finished replaces my e-brake shoes, set the shoes snug against the drums so that there is some drag., I also adjust parking brake handle, tighten done and test to see if it works. Car just kept rolling back on unlevel surface. Did I miss a step?
05-28-2009, 02:40 PM
#2
Car: e30is
are you sure your cable is still good?
05-28-2009, 02:43 PM
#3
Car: 325IS 87-325IC 89-IC
I believe they have self adjusting capacity. Drive the car backwards down the road and do some heavy braking. do this a few times it does help adjust he emerg brakes. Unless I am mistaken...
05-28-2009, 02:58 PM
#4
Car: e36 m3
You definitely are mistaken (or smoking crack)....the e-brake mechanism has no connection to the hydraulic brake line.
How did you adjust the parking brake handle? Maybe you adjusted it the wrong way? and made the cable too loose ?
Also did you ensure the little piece at the bottom where the cable comes in was free and not seized? If that small part is seize your brake shoes won't budge.
05-28-2009, 04:40 PM
#5
what piece at the bottom? I didn't check that part, what does it look like? pics preferred.
thanks
05-29-2009, 09:41 AM
#6
Car: e36 m3
Part #5.
05-24-2010, 07:17 PM
#7
Car: '89 325is
If that part is seized, first, how do you get it off, and second, if you replace it, will a seized brake generally work?
From Eyesore to Heat Score
05-24-2010, 07:43 PM
#8
oh wait! come to think of it... yes! I think I was smoking crack at the time...lol.
05-25-2010, 12:34 AM
#9
Car: e30 with e91 beater
LOL jeezus Ceeker I swear you just make stuff up.
Part #5 almost always seizes up, and unless you know that its supposed to move it looks like it doesn't. Rip it back out, soak it in oil and see if it frees up.
05-25-2010, 06:42 AM
#10
Car: '89 325is
I've been pulling on it by hand, is there a tool or any advice that will makee it come off easier? Or do I just have to keep yanking on it? Does it have a catch or anything that needs to be undone to allow it to come off?
05-25-2010, 07:21 AM
#11
Car: e30is
#5 should be held on by the #6 pin, that can be a pain to take off
05-25-2010, 08:05 AM
#12
Yeah, I kinda like it..keeps people on their toes...LOL
