Old 05-24-2009, 12:15 AM   #1
john88
Need advise e39 ?
I have 1998 e39 528i have 180000km on it, already replaced ball join and control arm at 90000km about four years ago, but recently i found that my steeling wheel shaking on hwy during 80 to 120 km wheel, balance already done it is ok, do i need another replacement of ball join and control arm soon? thanks!
john88 is offline   Reply With Quote
Old 05-24-2009, 12:28 AM   #2
porksoda
You can try thrust arm/control arm bushings. These are the items that go. Lot of techs recommend to get the whole arm replaced... which is what i did about 110ish K km.
porksoda is offline   Reply With Quote
Old 05-24-2009, 12:39 AM   #3
MLue1
MLue1's Avatar
Sounds like the classic BMW Trust Arm Bushing problem (do a search on this forum), but at 180K if you haven't done any suspension maintenance since 90k then you're probably due for some at both front and rear.
Mark
'99 E39 540iT
Old 05-24-2009, 01:05 AM   #4
john88
Where the shop I can get it check and fix it with good job and price beside dealer?
Old 05-24-2009, 01:29 AM   #5
MLue1
MLue1's Avatar
Check out some of the shops who sponsor this forum. RMP is pretty good but there are others as well.
Mark
'99 E39 540iT
Old 05-24-2009, 11:50 AM   #6
porksoda
rmp motors, lakeside motors.
Old 05-24-2009, 11:16 PM   #7
Fern
Fern's Avatar
torque all the wheels to proper specs... It fixed my problem with 80lb ft.
Exmodeldater :-)
'99 BMW 540i6 (black on black)
'99 Lexus Rx300
Fern is offline   Reply With Quote
Old 05-27-2009, 12:18 AM   #8
john88
How much RMP charge to fix this?? thanks!
Old 05-27-2009, 07:55 AM   #9
porksoda
any indy shop will run you between 700-1000 depending what parts you need beside the thrust arms.
Old 05-27-2009, 12:47 PM   #10
MLue1
MLue1's Avatar
I don't want to mislead you, since you haven't done much in terms of suspension maintence you really should get a mechanic to inspect the suspension and give you an estimate, as I said before at 180k chances are you will need more than just the thrust arm bushings. If you've worked on cars before it is reallly is not difficult to change out the parts but you have to wait until the weight of the car is on the suspension before tightening some of the bolts.
I would get the inspection / estimate and go from there... .
Mark
'99 E39 540iT
Old 05-28-2009, 12:50 AM   #11
john88
thank you for your advise!
