Old 05-06-2009, 10:23 PM   #1
tdotbimmer
Question Stereo Equipment Specs - HELP!
Hi guys,
I want to do a custom install in my 1992 850i and I have been researching on high end components and need some clarification on specs. I am yet to purchase all the items with the exception of the HU which I have.
Head Unit
Alpine IVA D310
Interior speakers
5.25" MB Quart PVI 213
* Sensitivity: 87 dB
* RMS Power Range : 50 Watts
* Peak Power Handling: 110 Watts
* Frequency response: 52-32000 Hz
* Diameter: 5.25 Inch
6.25" MB Quart PVI 216
* RMS Power Range : 70 Watts
* Peak Power Handling: 140 Watts
* Frequency response: 38-32000 Hz
* Diameter: 6.5 Inch
Interior Amplifier
4 Channel MB Quart PAB 4100
* RMS@ 4 Ohms : 100 W x 4 ch
* RMS@ 2 Ohms : 150 W x 4 ch
* RMS@ 4 Ohms : 300 W x 2 ch (bridged)
* Frequency Response (-3 dB) : 10 Hz - 30 kHz
* Damping Factor : > 200
Subwoofer
2 10 JL Audio 10W3v3-? - Where ? is 2 ohm, 4ohm OR 8ohm
For 2 ohm subwoofer
* Sensitivity: 85.37 dB
* RMS Power Range : 100-500 Watts
* Peak Power Handling: 1000 Watts
* Impedance: 2 Ohm
* Low Frequency response: 25 Hz
* High Frequency Response: 250 Hz
* Diameter: 10 Inch
For 4 Ohm subwoofer
* Sensitivity: 84.87 dB
* RMS Power Range : 75-300 Watts
* Peak Power Handling: 600 Watts
* Impedance: 4 Ohm
* Diameter: 10 Inch
For 8ohms subwoofer
* Impedance: 8 Ohm
* Diameter: 10 Inch
Subwoofer Amplifier
MB Quart PAB 1200.1D Mono Amp
* RMS Power Range : 600-1200 Watts
* Number Of Channels: 1
* Built In Crossovers: Yes
* RMS Power Range @ 4ohm: 1 x 600
* RMS Power Range @ 2ohm: 1 x 800
* RMS Power Range @ 1ohm: 1 x 1200
My question:
Which Subwoofer W3v3-? would my amplifier be able to work with?
Would the 4 channel amplifier be okay as well?
Links
Interior Speakers
http://www.mbquartusa.com/premium_speakers_specs.html
Amplifiers
http://www.mbquartusa.com/premium_amps_specs.html
Subwoofer
http://mobile.jlaudio.com/products_s...p?series_id=24
1992 E31 850I aka M3'S FATHER -- Brilliant Red/Black Interior
2 Wallets' List:
19" DPE LS15 - 19X8 F | 19X10 R | NITTO INVO 245/35/19 F | 285/30/19 R
2002 E46 aka M3'S STEP SON -- Topaz Blue Exterior/Tan Interior
tdotbimmer is offline   Reply With Quote
Old 05-07-2009, 10:53 AM   #2
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Your sub amp is stable down to 1ohm so either the 2ohm or 4ohm JL will work.
However I would go with the 2ohm as it has the highest peak and your amp says it can put out 800 rms at 2 ohh and the peak for the 2ohm JL is 1000 watts
Stanceiseverything.com
Old 05-07-2009, 10:58 PM   #3
tdotbimmer
Thanks. Will double check with 1 or 2 stereo shops.
2 Wallets' List:
Old 05-08-2009, 09:35 PM   #4
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
I'm by no means an expert in this subject, but I can point you in the right direction if you're in for some good reading about car audio.
www.the12volt.com is a great site for this type of thing, and probably more active than our sub-forum here.
Good luck and can't wait to see it.
-Dan
95 530i|Modifications - Work.
ACS_DAN is online now   Reply With Quote
Old 05-25-2009, 03:04 PM   #5
Randy
Randy's Avatar
wow. thats a pretty nice setup.
Randy is offline   Reply With Quote
