Old 05-12-2009, 10:43 PM   #1
Blown M3
M3 S52 Cam Timing
I am having trouble getting the (Cam timing) right for my 98 M3 After replacing the head gasket. I have followed all the directions in the Bently Manual, but there is still a Code. (P1519 'A' camshaft position actuator bank 1) Coming up. I think that it is the cam timing. Can Anybody help me out with this.
Blown M3 is offline   Reply With Quote
Old 05-12-2009, 10:48 PM   #2
JazzM
take a look at the stage I document in terms of setting the timing properly:
http://www.drvanos.com/index.php?opt...=16&Itemid=15#
T.
T.
JazzM is offline   Reply With Quote
Old 05-13-2009, 12:09 PM   #3
Blown M3
I have also heard that if you get a magnet near the cam sensor it will not work properly (Throw a code). Is this true. I has a magnet near, if not touching the cam sensor because I dropped a nut and a magnet was the only way to pick it up.
Old 05-13-2009, 02:19 PM   #4
MANDD
Autobahn East
If you have a fax I can send you the correct BMW Procedure. If you are near my area you can pick up the documents.
There is a specific way of adjusting the vanos unit on the M/S52 lump.
905-686-2700.
Mark.
MANDD is offline   Reply With Quote
Old 05-13-2009, 02:37 PM   #5
Blown M3
Yes I do have a fax (613)623-1172 and it would be appreciated if you could fax me the proper way to adjust the cams with the vanos.
Old 05-13-2009, 03:25 PM   #6
MANDD
Autobahn East
I will send it now, call if you do not get it.
Regards,
Mark
Old 05-13-2009, 07:13 PM   #7
Blown M3
Thank You I recieved ther fax. I hope it helps
Once again Thanks
Old 05-13-2009, 08:39 PM   #8
Blown M3
MANDD could you please fax me to instlation of the cams right from step 1 from putting the chain on the primary cam sprocket on the exhaust cam and where it goes on the cam. I think it goes to the left of the threaded holes, but I'm not sure, that is what the bentley manual says but there is still a code comming up.
Old 05-13-2009, 11:29 PM   #9
Blown M3
Thank you for all the help. Tonight I seem to have it running fine with no codes.
Old 05-14-2009, 05:04 PM   #10
1519 is also the code the ecu would throw if your vanos is jamming (seals worn out)
