Old 05-10-2009, 07:33 PM   #1
Gamite
Gamite's Avatar
Mom's E34 overheating
I changed the thermostat, the fan clutch looks to be a little loose, but I touched the rad and it was still cold.
The car is sitting at an incline, is it possible that there's an air pocket somewhere and it's preventing the coolant from moving into the rad?
www.gamite.net
Old 05-10-2009, 07:46 PM   #2
ImolaZHP
ImolaZHP's Avatar
did the temp gauge shoot up really quickly? if so, probably an air pocket like you said. try bleeding the system and go from there
ImolaZHP is offline   Reply With Quote
Old 05-10-2009, 07:50 PM   #3
344i
344i's Avatar
not likely, what is the coolant level like Jullian? Did you turn on the heat full blast?
I would open the rad, turn on car let it idle and warm, see how much coolant is in the rad cold and how much gets sucked up, turn the heat on full blast and see how much gets sucked up. Most likely youre just low on coolant, and need to add some. if the rad's level is low when cold and empty when the engine takes in coolant, youre definately low and need to add.
344i is offline   Reply With Quote
Old 05-10-2009, 08:03 PM   #4
Gamite
Gamite's Avatar
the reservoir on the M30 is not on the rad, so you cannot see how much coolant is in the rad. I turned the heating on, and no hot air came out.
I turned the car around, now the nose is pointing down. I suspect a large air pocket, but the bleeder valve is broken so I cannot bleed.
I filled up the reservoir and its still full right now.
www.gamite.net
Old 05-10-2009, 08:36 PM   #5
BigD
the misanthropist
BigD's Avatar
How old is the fan clutch? Don't try any BS tests with it, if it's not like a few years old, change it. And what do you mean by the fan clutch being "loose"? If you mean the shaft, if it has more than 1mm play your waterpump is dead/dying.
If it's not the fan clutch then it could be a toast HG. Check the dipstick for white froth, and the coolant reservoir for bubbling - it looks like this:
Old 05-10-2009, 08:41 PM   #6
BigD
the misanthropist
BigD's Avatar
Fix it... get a new t-stat cover if you can't.
Old 05-10-2009, 08:57 PM   #7
Gamite
Gamite's Avatar
Fan clutch was not fully engaged, but it works with heat, since the rad was not hot, it did not force it to fully engage, which is why I doubt it is the fan clutch.
Tube going down from the T-Stat housing leading to the rad was not hot either. I suspect air in the housing. I'm rummaging through my spare parts to see if I have an extra cover.
www.gamite.net
Old 05-10-2009, 10:22 PM   #8
BigD
the misanthropist
BigD's Avatar
The tube going down is the return. Is the top rad hose hot?
Old 05-10-2009, 10:28 PM   #9
$500bimmer
did you put the stat in backwards?....i have seen it happen....
$500bimmer is offline   Reply With Quote
Old 05-10-2009, 10:36 PM   #10
Air in the system, for sure! Let it cool off for a bit, level should go down, so add more coolant, repeat several times...its another way of bleeding the system...
Old 05-10-2009, 11:42 PM   #11
Gamite
Gamite's Avatar
Fil, do you have an extra cover if I don't have one?
www.gamite.net
Old 05-10-2009, 11:43 PM   #12
Gamite
Gamite's Avatar
top rad hose is hot, bottom one is cold
www.gamite.net
Old 05-11-2009, 12:06 AM   #13
344i
344i's Avatar
thats messed up, air pocket or clog in the rad, it should be circulating!
Old 05-11-2009, 09:45 AM   #14
My vote goes for bleeding the system, it could take hours sometimes.
If you can borrow a pressure bleeder, since your bleeder vavle is broken.
After you ruled out air in the system, my next guess goes to the water pump, check to make sure it is circulating, before assuming it is the HG.
Old 05-11-2009, 12:24 PM   #15
Gamite
Gamite's Avatar
once I find the part. I will see.
www.gamite.net
