Old 03-23-2009, 02:25 PM   #1
BigD
the misanthropist
BigD's Avatar
Pads - front vs rear, diff compound?
I'm shopping around for Hawk HT10 pads and this one shop I called was pretty shocked to hear that I am putting them in the rear too, saying it's normally too aggressive for a rear pad.
Is there anything to this? Should I get a tamer compound like HP+ or something for the rears? I certainly wouldn't mind because they're expensive as hell in HT10.
FWIW this is a track-only car.
Old 03-23-2009, 03:13 PM   #2
theblue
old school US member.
theblue's Avatar
I ran HT-10s on the front and HP+ on the rear of my lancer evolution w/ race tires and it worked pretty well.
it all depends on your needs really... you might have trouble keeping the HT10s up to temp on the back of your car which will cause them to crumble causing a dangerous situation.
02 BMW X5 // 97 BMW 328iC // 89 325is w/ M50 swap // 06 Audi A3 w/ APR stage II
Old 03-25-2009, 03:06 PM   #3
Gleb
E30 M20
Gleb's Avatar
10 Front / + Rear... worked well for me. But I started with +'s all around, then 10/+ and at the end I had 10/10 - NO PROBLEMS!
Whatever combo you choose - you'll like these pads.
Old 03-25-2009, 03:28 PM   #4
BigD
the misanthropist
BigD's Avatar
Thanks, yeah I've talked to a bunch of guys about this now and the consensus seems to be to just go with HT10 and if for some odd reason I have issues then change, but I'll probably be happy with it.
Where do you get your HT10s? I'm trying to shop around but the Canadian suppliers rip you a new asshole. The cheapest I've found, after tax, for rx7 front and e30 rear is 473. From tire rack, including shipping and currency conversion, it's 380.
Old 03-25-2009, 03:35 PM   #5
Gleb
E30 M20
Gleb's Avatar
416-514-0284 Precision Tuning.
But it was a long time ago since I bought anything in Canada. I do most of my car shopping in the US, when I travel with the Grand-Am guys.
Old 03-25-2009, 03:40 PM   #6
BigD
the misanthropist
BigD's Avatar
He says he can't get them "now". Wtf
Old 03-25-2009, 05:34 PM   #7
theblue
theblue's Avatar
HT-10 are a problematic pad, honestly I won't buy them again.
I found that blues were plenty for track day use in my case.
why not go with Hawk blues, blacks, or dtc-60, dtc-70 depending on your exact needs.
Old 03-25-2009, 07:46 PM   #8
BigD
the misanthropist
BigD's Avatar
I'll give them a shot, I can't wait to try them. I'd get DTC but they're not available for my application.
Old 03-26-2009, 04:20 PM   #9
328trackrat
Big D you should be fine since I believe you have S50 swap e30...Cars with stock power can have a hard time heating up a ht-10 on a rear like others have mentioned. With your power you shouldn't have much of a hard time doing so. I ran HP+ all around and with stock 328 power I wasn't anywhere near the limits of my brakes.
328trackrat is offline   Reply With Quote
Old 03-26-2009, 09:19 PM   #10
Gleb
E30 M20
Gleb's Avatar
I don't know where you guys get these "problems" with 10's. I used them with great results with the stock M20... maybe you are just not braking hard enough
I had this conversation with James Clay of Bimmerworld, when I ordered my first set of 10's. I asked him the same question... his reply : "Bullshit."
D, get the 10's, you will love them. Depending on how many track days you do, they should last a season. Just don't waste them on street driving. Should be cheaper too, in the long run.
I have a bunch of old Carbotech pads if you want them (free), not a lot left on them, but should be enough for a track day. Let me know if you want them, cause I have no idea where they are and it will take me sometime to find 'em.
Old 03-26-2009, 10:55 PM   #11
BigD
the misanthropist
BigD's Avatar
Thanks guys. Yeah I wouldn't be considering these if this was a daily with part time track status. This car stays in the garage until it's time to get raped. I did a testing day at Dunnville in the car last year and it was scary with street pads. The brakes went away after just a few laps and I wasn't even driving it hard, just hoping that the car doesn't break. But I got up over 100mph on the front straight thanks to the S52. My pedal stayed hard but I found myself almost twofooting it by the end. When I went to put in the RX7 brakes I pulled my pads and they were falling apart like charcoal.
Old 03-27-2009, 12:10 PM   #12
theblue
theblue's Avatar
mine started to crumble after two days at the glen.. I did drive home on them and then changed them out. When I contacted Hawk, they told me there is not warranty on track pads and blamed me for driving home on them.
I'm willing to take some of the blame, but I've never had this problem with the blues and other pads. Money down the drain
Old 04-21-2009, 05:12 PM   #13
DriveItSideways
HP+ is a great pad, we run them F/R on our sentra spec v race cars and they perform 10/10.
Anything above the HP+ should be used on real power house cars.
DriveItSideways is offline   Reply With Quote
Old 04-21-2009, 08:09 PM   #14
JazzM
Performance Friction http://www.performancefriction.com/ makes much better racing pads then Hawke.
Do some research.
T.
T.
Old 04-22-2009, 10:25 AM   #15
theblue
theblue's Avatar
the spec-V is a pretty lightweight car... once you get over 3000lbs. and you're using track tires HP+ is not enough regardless of power.
