Old 12-14-2008, 07:12 PM   #16
slimjim
Almost Sideways
Originally Posted by Trouble65 View Post
Sorry Dinan_M5 pressure washing is the worst possible way to wash your engine bay. The high pressure will eventually find a weak spot in rubber seals and destroy them. I always wash my engine bay with some type of degreaser agent followed by warm water and soap. After that I rinse the engine compartment and use compressed air to get rid of the remaining water.
wrong, i do it to the e30 teice a month in warmer weather and i have NEVER had any problems, and wat rubber seals would u be spraying exactly? and if they are falling apart, means its time to replace them.
slimjim is offline   Reply With Quote
Old 12-14-2008, 07:21 PM   #17
Trouble65
How can I be wrong when you speak to mechanics that work on these vehicles tell you not to do it.
Trouble65 is offline   Reply With Quote
Old 12-14-2008, 07:22 PM   #18
Trouble65
, and wat rubber seals would u be spraying exactly? .
The ones around your electrical connections.
Old 12-14-2008, 07:44 PM   #19
slimjim
Almost Sideways
how can i be wrong when ive done this to multiple cars, both new and old, and nothing has ever happened.
just avoid the ecu and be carefull of any wires.
Old 12-14-2008, 07:54 PM   #20
Trouble65
Because you got lucky. I did it in my E30 had problems did it on my e36 had problems not every time mind you, however that one time is too much.
Old 12-25-2008, 01:07 AM   #21
Bavaria
Southern Beirut
Bavaria's Avatar
Send a message via MSN to Bavaria Send a message via Yahoo to Bavaria
ummm, when i got my car back from bimmersport Charlie said i can clean it with water, just avoid the electrics with a bag or something and it should be fine.
Bavaria is offline   Reply With Quote
Old 12-25-2008, 02:13 AM   #22
Dado 540
Dado 540's Avatar
I believe its comming down to personal preference and experience. The fact is that either way you wash it, you gotta cover up the electrical components.
Old 04-17-2009, 12:03 AM   #23
juzer
7000 RPM
juzer's Avatar
Spray first with degreaser, brush if needed, than wash with hose all over, avoid water near ignition/ electronic parts, you can use just regular towel to cover parts you dont want to be watered, wipe out and let it dry.
juzer is offline   Reply With Quote
Old 04-17-2009, 10:03 AM   #24
I pressure wash the range Rover's engine bay after a day out in the mud. Never had any issues.
I don't DARE wash the M5 engine, I just polish it up with a rag and a degreaser.
Old 04-17-2009, 11:32 AM   #25
MiroE36
MiroE36's Avatar
I drive my car into a lake and drive out, and i'm good
Old 04-17-2009, 11:47 AM   #26
328IScreamer
328IScreamer's Avatar
I have wondered this myself for a while. Up until now all I have done is just get some rags and wipe all the dirt off.
How safe is it exactly to pressure wash? what happens if i spray the alternator or the water gets into some connections?
Old 04-17-2009, 12:29 PM   #27
Gamite
Gamite's Avatar
Pussy. Wash that shit.
Use 303 Aerospace protectant to finish up with. You can get it from Canadian tire.
www.gamite.net
Old 04-17-2009, 08:02 PM   #28
zubbie
Happy Happy Joy Joy
zubbie's Avatar
Best stuff out there hands down!
89 535iA ; 93 M5
zubbie is offline   Reply With Quote
Old 04-18-2009, 06:28 PM   #29
NipponM5
NipponM5's Avatar
I bought a new pressure washer yesterday. They're on sale at canadian tire. On the pressure washer it tells you not to spray the pressure washer with the stream. So, do you really want to pressure wash your engine?
NipponM5 is offline   Reply With Quote
Old 04-18-2009, 07:15 PM   #30
Dado 540
Dado 540's Avatar
How much?
E39 540i Sport
