Old 04-09-2009, 02:34 PM   #1
UltimateDriv
Bimmerhead
UltimateDriv's Avatar
Send a message via AIM to UltimateDriv Send a message via Yahoo to UltimateDriv
Any PC builders or computer techs on here? or maybe u know someone...
i built a computer and am having trouble getting it to work properly. it turns on, and everything seems to work. but i get no video or beeps???
so i've been racking my brain trying to troubleshoot...and am about to give up, and get some help.
heres what im dealing with
CPU
http://www.tigerdirect.ca/applicatio...?EdpNo=3751531
motherboard
http://www.tigerdirect.ca/applicatio...srkey=a780gm-a
memory
http://www.tigerdirect.ca/applicatio...049&CatId=2264
so if anybody can help or knows somebody who can, let me know....ill compensate you for your time/help.
oh i also need a copy of vista to load on here
UltimateDriv is offline   Reply With Quote
Old 04-09-2009, 02:56 PM   #2
Jim .E.
E90 n00b
Jim .E.'s Avatar
possible scenarios:
- memory could be bad, test with only the cpu and mobo. disconnect ram, video card, hdd, cd-rom, floppy - all extra peripherals.
if that doesnt work THEN your motherboard is touching the case somewhere underneath causing a short, try putting it on a antistatic bag out of the case and turning it on
Old 04-09-2009, 03:02 PM   #3
344i
344i's Avatar
Ok! Look at your keyboards when you turn it on. If it lights up (caps, num locks) the motherboard posts, and works. Could be cpu or ram.
No lights= dead board. If you have lights , check with another stick of ram. If that doesn t work, you have a dead cpu.
344i is offline   Reply With Quote
Old 04-09-2009, 03:05 PM   #4
UltimateDriv
Bimmerhead
thanks for the input guys...
the keyboard does light up as soon as i power it up, but just a flash for a second
Old 04-09-2009, 03:07 PM   #5
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Can you push caps and make the light turn on?
Old 04-09-2009, 03:08 PM   #6
344i
344i's Avatar
So its not the motherboard, its 90% the ram, or 10% chance its the cpu.
The keyboard will light up and turn off, this means the motherboard is posting correctly and in working order. Try a different stick of ram first. If tyou have more then one stick of ram, pull them all out. Try one at a time, until you get boot. even if you get boot, with the first stick try them all to find the crapped out one, and RMA it.
Old 04-09-2009, 03:11 PM   #7
UltimateDriv
Bimmerhead
nope
Old 04-09-2009, 03:12 PM   #8
344i
344i's Avatar
nope
capslock is irrelevant, it will not work, until boot ex: video comes on.
Old 04-09-2009, 03:20 PM   #9
UltimateDriv
Bimmerhead
ill try that...thanks
Old 04-09-2009, 03:50 PM   #10
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
odd you say u get no beeps.. which you would with ram, cpu , vid..
I've had a couple of bum'd (new out the box) asus ide cables, took a while to figure that out..
1 was helpful , pulled it from a h/d black clip stayed in the h/d
not being an ass but Bios settings are correct? is it jumperless the board? are all pins placed correclty if its not?
Old 04-09-2009, 04:29 PM   #11
SickFinga
SickFinga's Avatar
What video card do you have? How powerful is your power supply?
Old 04-09-2009, 04:32 PM   #12
UltimateDriv
Bimmerhead
the mobo has a built in video card...but i also have an ATI Radeon X1300 PCI
power supply is 450w
Old 04-09-2009, 04:35 PM   #13
SickFinga
SickFinga's Avatar
Is ATI installed as well?
Old 04-09-2009, 04:49 PM   #14
slemmer
Driving in the fast lane
slemmer's Avatar
There may be a conflict with the video card. Try removing the add on video card and test using the onboard video. Is the monitor good?
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 04-09-2009, 07:20 PM   #15
344i
344i's Avatar
lol
