Old 03-18-2009, 12:58 AM   #16
///tyron
///tyron's Avatar
Originally Posted by e30_kid89 View Post
.82ar will be good. size for a s52.
///tyron, I'd bet they use that t3/t4 for the m50 and maybe m52...I dunno if its me but a .63 seems on the small side for an s52 (3.2L)
Too much backpressure from small sizing = EGT's go through the roof.
It is small. I was just comparing the t3/t4 to the gt30r 1.06 a/r. If that turbo can make 325rwhp with a .63a/r on a 2.5L the gt30 with a 1.06a/r will flow well .
Big D If you look at the compressor map, you should require around 44lb/min of air. At your boost level of 10psi to make your power goal. that should indicate a 1.6 pressure ratio.
The Garrett turbo tech site says "this means that for any engine, in order to make 400 Hp, it needs to flow about 44 lb/min"
If you look at the map you're completely off the efficiency island. I'd say you'd have to run at least 15psi to be with in both the 30r and 35r's efficiency
heres a thread for you. S52 t3/t4 Pump gas 12 psi 360rwhp
http://forums.bimmerforums.com/forum...d.php?t=578916.
///tyron is offline   Reply With Quote
Old 03-18-2009, 01:06 AM   #17
e30_kid89
The Afro-stig
e30_kid89's Avatar
I see what you're saying now... If the pressure ratio is 1.6 then yea he'll be off the map.
In that case I'd agree with you on a GT30r with a 1.06 a/r housing being a better match.
Old 03-18-2009, 11:17 AM   #18
BigD
the misanthropist
BigD's Avatar
Again please provide the math. I think my estimates were all pretty reasonable and I end up at a pressure ratio of over 1.9. You can't just pull out boost numbers out of thin air. 15PSI in an efficient DOHC head (if I remember correctly, I assumed .97 volumetric efficiency, which is pretty conservative) of a 3.2 at 7000 rpm at sea level is going to make a hell of a lot more than 400hp.
Old 03-18-2009, 12:56 PM   #19
///tyron
///tyron's Avatar
I used a basic equation with your numbers in the equation, i didnt just make up the numbers.
10 psia + 14.7 psia = 24.7 psi absolute pressure in the manifold
24.7psi/14.7 = 1.68 pressure ratio
Old 03-18-2009, 03:10 PM   #20
BigD
the misanthropist
BigD's Avatar
Only according to Garrett, you have to use 1psi pressure loss through inlet depression and 2 psi for a typical pressure loss through piping etc (which, since I'm no expert, is probably even optimistic) for calculating the ratio, so it's 26.7/13.7 = 1.95
Old 03-20-2009, 10:26 AM   #21
Try this out:
http://www.not2fast.com/turbo/glossary/turbo_calc.shtml
Remember that calculations and math will only approximate things; experience is the only true measure. I'm sure there are guys running different turbos on the S52 that have posted numbers. Ask the Google.
Edit - where did you get this info: ".97 volumetric efficiency, which is pretty conservative"? Race motors can go above 1 at the right RPM range, but most street motors don't approach 1 from what I understand.
Old 03-20-2009, 10:46 AM   #22
BigD
the misanthropist
BigD's Avatar
From Garrett - they say figure 96-99 for a good DOHC head.
Old 03-20-2009, 11:06 AM   #23
Wow!
Old 03-28-2009, 09:34 PM   #24
90E30i
90E30i's Avatar
Choosing the right turbo is half the battle. Manifold design and intercooler size and design also play a major role. For example a twin entry exhaust housing with a split pulse manifold will give you huge improvement over the same turbo with a single entry manifold. I suppose being a track car you want to have good mid range power to pull you out of the turns.
90E30i is offline   Reply With Quote
