Thread Tools Rating: Thread Rating: 59 votes, 5.00 average. Display Modes
Old 12-11-2008, 12:52 PM   #631
Originally Posted by dirtbleed View Post
15"x6.5" ET 33. Will they fit an 89 325is. Wheels are nice BBS basketweaves off of a VW Corrado.
Done it. 205 tires are the biggest you can go without spacers.
Old 12-11-2008, 01:17 PM   #632
dirtbleed
Thnx,
You're car sits nice and I like the "period correct look" with the 15" wheels. That VW set sold fast. I think black looks better with a white car. Red and silver looks right. I'm gonna go Falken RT615 205/50-15. maybe with Konig Rewinds with the spokes painted black. Keep the silver lip.
dirtbleed is offline   Reply With Quote
Old 12-12-2008, 11:46 AM   #633
I had the RT-615s on them too, great tires.
I only had that setup on the car for about a week, I really only bought them due to curiosity (wanted to know if the 615's could clear the struts with them). They need spacers to look good.
Old 12-12-2008, 12:04 PM   #634
dirtbleed
I don't want spacers. I might go with these and paint the center black as well. 15x7 et20
Old 01-19-2009, 01:19 PM   #635
Duct_Taper
Sticky
Duct_Taper's Avatar
What size spacers would you need to make them look good? I am kind of considering a set:
http://toronto.kijiji.ca/c-cars-vehi...QAdIdZ99976527
Duct_Taper is offline   Reply With Quote
Old 01-23-2009, 01:06 PM   #636
15mm would be enough. For the record, they have the exact same specs as the BBS RZ's I posted above on my car.
Old 01-26-2009, 07:33 PM   #637
Duct_Taper
Sticky
Duct_Taper's Avatar
Another question... tried to search thru the thread but had trouble finding anything specific...
17x8 ET20 with 205/40R17 (yes I know the tires are a bit small, but meh... pretty close)
Fit OK?
Old 01-27-2009, 12:52 PM   #638
Fit OK?
Yup, that fits fine.
Old 01-27-2009, 12:59 PM   #639
Duct_Taper
Sticky
Duct_Taper's Avatar
Thanks.
Old 01-27-2009, 12:59 PM   #640
mortenstj
Hi
First, sorry about my bad english skills.
It's time for new wheels for my E30, and i found some nice rims that i will order soon. Keskin KT1.
The size are: 8.5x17 ET 20.
with 215/40 tire.
My question is: Will this size fit perfect on a E30 Coupe? I don't understand exactly what offset (ET 20) means, but what do you think?
Will i ran into some problems?
My car is lowered, but not insane lowered
Here is the car with 17'' 215/40
mortenstj is offline   Reply With Quote
Old 01-27-2009, 01:14 PM   #641
Originally Posted by mortenstj View Post
Hi
with 215/40 tire.
Yeah those are no problem. A member here ran those in front and the 17x10 version in the rear.
With the 215/40/17 tire the most you would have to do is a slight fender roll in the back. But depending on the tire used, you may be able to get away without it.
Old 01-27-2009, 01:18 PM   #642
mortenstj
Oki
Do you mean i need fender roll, if i go for 17x10 in the rear? Or 8.5x17 also?
Old 01-27-2009, 01:20 PM   #643
Oki
17x8.5 also. But again, you most likely won't need it.
Old 01-27-2009, 01:24 PM   #644
mortenstj
Ok. Sounds good.
I think i will buy ET30, then use 10mm spacer. That will be ET20 right?
Failsafe
Old 01-27-2009, 01:33 PM   #645
Ok. Sounds good.
Failsafe
No, don't do that. Get the ET20 version (bigger lips). It's seriously not a concern.
