Originally Posted by richmak
Forgive my ignorance ... someone told me the feed for DRL and the feed for highbeam are separate. This means if the relay is added to the DRL feed then I won't be the a**hole blinding people with the high beam.
About disabling the DRL ... it is actually quite sarcastic ... I had to pay someone to enable the DRL when I imported this 5 wagon from PA last Sept ... now I am paying someone to disable it
You could be right about the feed, but I don't know enough about how the LKM works in the E39. Still searching for an inexpensive Bentley for this car.
If you find a place for no-DRL, let me know
Pure white is a trade off because you'll need extremely blue tinted bulbs, which will in turn reflect a hideous blue color when they're off (and yer parked). You can use LEDs but then you basically have no high beams.
Yellow isn't so bad. If you can't beat em, join em. Make it as yellow as possible
