Old 12-25-2008, 12:59 PM   #16
SamE30e
SamE30e's Avatar
its not always about bang for the buck and more power, he has his reasons why he is interested in a SC build, and I agree with him. Yes you may be able to make cheaper and a bit more power with a turbo, but the SC kit will provide constant power through out the power band. unless your hitting a twin turbo on a inline 6 its hard to get a system that will boost from 500rpm to 8000rpm. a well built SC kit will provide more power over the entire powerband wich can result in more power overall because there is no lag time.
Turbo lag is an excuse. A properly sized turbo will give boost from 2000 all the way to redline. When do you ever need power under 2000 except on the highway cruising.
Off boost = better gas milage.
Everyone knows Turbo > SC unless you're a bitch and drive a domestic V8.
85 325 - Turbo M52B28.
Old 12-25-2008, 04:01 PM   #17
slimjim
Almost Sideways
ok this is not suposed to be a thread about which is better, ive made my decision. ....so do u guys know of any companies still making SC kits for e30's?
slimjim is offline   Reply With Quote
Old 12-25-2008, 04:55 PM   #18
NOTORIOUS VR
NOTORIOUS VR's Avatar
Still? I wasn't aware of any companies making S/C kits for E30's.
Old 12-25-2008, 05:24 PM   #19
SamE30e
SamE30e's Avatar
Nobody does, because they're dumb.
TCD.
Old 12-25-2008, 05:55 PM   #20
v_bimmer
Jailbait FTW
v_bimmer's Avatar
Originally Posted by NOTORIOUS VR View Post
S/C takes power to make power. Couple that with belt issues, after cooling issues, space issues. It's much easier and cheaper to make a well designed turbo system then a custom S/C kit.
And I don't know what you're talking about 'random power' of turbos.. if you have someone properly match all the parts of a turbo kit up to your power goal you'll have almost an equal power band as a S/C setup.
New turbo technology has simply come a long way to think that turbo system have to be peaky in nature. That and there are too many people that just throw on GT40's.
Modern ball bearing turbo + electronic PWM boost controller + very linear boost and power levels.
Just something to think about.
i agree with you 100%, plus nobody makes SC kits for E30 (from my knowledge) and what is the point of supercharging something that does not have power to begin with
Old 12-25-2008, 05:57 PM   #21
slimjim
Almost Sideways
ud be surprised, with little upgrades, im neck and neck with a mk2 vr6
Old 12-25-2008, 08:26 PM   #22
SamE30e
SamE30e's Avatar
Thats not saying much.
Old 12-25-2008, 09:15 PM   #23
e30_kid89
The Afro-stig
e30_kid89's Avatar
^^^LOL...@ Sam.
we're not trying to be hard asses or anything but to answer your questions there is NOBODY selling a "kit" to supercharge your m20...If you really want to supercharge as bad as you do the next best thing would be an budget m50 Non-Vanos swap, delete A/C (so you keep the same weight up front) and supercharge that since there are off the shelf s/c kits that are for e36s but can be made to fit in an E30.
Old 12-25-2008, 09:47 PM   #24
SamE30e
SamE30e's Avatar
Or make your own SC setup. Goto the junk yard, find a GM 3800, steal the eaton m40 twin screw sc off it, then start there.
Old 12-25-2008, 11:02 PM   #25
I have an eaton m90 I would go cheap. I was going to mount in where the alternator goes and put the alternator in place of the compressor. I also have a pulley that fits the M20 for it. Custom brackets, intake and charge pipes would have it running, and a supercharger is a good candidate for a BEGI FMU and 21# injectors for fuel management.
The eaton I have needs a new front seal and oil, but you'd do that with any used SC. Rebuild kits are cheap, like $50 or so.
Old 12-26-2008, 12:14 AM   #26
NOTORIOUS VR
Originally Posted by e30_kid89 View Post
^^^LOL...@ Sam.
It's true... my friends E30 was a stock SETA before it went turbo. Just with a stand alone and a quick tune (no dyno tune) it would pull away from my Jetta VR6 no problem.
When he was on the stock Motronic I was able to pull on him.
An MK2 VR6 is only slightly faster then my MK3... so meh.
Old 12-26-2008, 04:48 AM   #27
1234
1234's Avatar
A supercharger would be good for a small bump in power I guess.
1234 is offline   Reply With Quote
Old 12-26-2008, 12:55 PM   #28
Small bump? More than that. You could double the torque of the m20 with a m90 properly tuned. The low end torque boost of a supercharger is far better than most turbos, and they're linear power development makes the motor behave like a much bigger NA motor. With a large supercharger you'd also see serious peak HP numbers, but the overall torque curve is where its at.
Old 12-28-2008, 12:51 PM   #29
richie_s999
http://www.rosemdesign.com/lowen/pages/supercharger.htm
this looks like a nice sc kit
Old 12-28-2008, 03:58 PM   #30
e30_kid89
The Afro-stig
e30_kid89's Avatar
Wow...I stand corrected..
