Old 10-22-2008, 08:22 AM   #1
champ0202
Over Heating?
For the last couple of weeks the temp gauge in my car (99 e46 323i) will shoot to the red after about 5 -10min of normal driving if I turn my car off at a red light and turn it on again after a few seconds everything seems fine, I am able to smell coolant every once and a while not sure if its a sensor or a sticking thermostat any ideas?
Thanks Tony
champ0202 is offline   Reply With Quote
Old 10-22-2008, 04:49 PM   #2
Tnd-_-b
1st Gear Stripper d-_-b
Tnd-_-b's Avatar
Send a message via MSN to Tnd-_-b
Uhm!!!???
I have the exact same car, i have replaced my raid twice. once cuz it had a leak in it. and the other time i drifted my car around a corner and my fan had touched my fan shround and damaged everything the raid the fan shroud was completely gone and the fan plades where all gone when i took of my skid plate everthing was in the bottom. it cost me about $250 to fix everthing. regarding your problem it could be a small leak. Is your coolant toped off? Have you taken a look to see or find out where the leak is coming from. Other then that all i can think of is ur thermestate, or could be faulty water pump.
Uploaded with ImageShack.us
Tnd-_-b is offline   Reply With Quote
Old 10-22-2008, 04:59 PM   #3
ImolaZHP
ImolaZHP's Avatar
^^listen to what he says, check rad for leaks and hoses, and the water pump failing on these cars is common. make sure you do this soon, an overheated engine will cost you$$$$
the thermostat can also fail in these cars but will normally just send the needle up at a slant/and or take a really long time to move anywhere
ImolaZHP is offline   Reply With Quote
Old 10-29-2008, 01:14 PM   #4
champ0202
overheating?
I can not see a leak anywhere, my fluid level has not changed and it is at top. I have replaced my water pump approximately 20000km - 30000km ago, the needle has not shot up into the red in the last week however I think I'm able to smell the coolant when I get out of the car (sometimes) this is driving me nuts I have been to a small shop and he took a look at the car and nothing appeared to be wrong, I'm wondering if i should just change the thermostat to be safe?
Old 10-29-2008, 04:33 PM   #5
when is the last time you bled your cooling system?
Old 10-30-2008, 08:26 AM   #6
champ0202
Overheating?
I had the system bled in February,
The car said it was overheating (needle in the red) this morning on the way to work. I turned off the car at a red light started it up again and had no more issue's all the way to work (about 15km) possible temp sensor? is the temp sensor easy to access?
Old 10-30-2008, 11:04 AM   #7
arsevader
Sounds strange. An overheated car would need longer than a red light to cool down sufficiently I say it's a gauge or sensor problem.
Get your cooling system checked out anyways but that doesn't seem right.
'85 325e
'90 325i
'02 325it
'03 320i
'96 Volvo 850R
Old 10-30-2008, 12:44 PM   #8
hamant
oddly enough, my car did the same think yesterday.. i think my thermostat is stuck open though...
so im changing that...
Mine was normal, then i looked at it 2-3 minutes later and it was in the red. I turned the car off and back on right away and the gauge went back to normal..
hamant is offline   Reply With Quote
Old 11-08-2008, 01:53 PM   #9
Oeelidu88
Talking Happy
bump and lurk---------------------------------------------------------------------------------We offer WoW Power Leveling and World of Warcraft Powerleveling,world of warcraft power leveling,, Buy Cheap WoW Power Leveling, enjoy best service:cheap wow power leveling, buy wow power leveling, world of warcraft power leveling
WoW Gold
Oeelidu88 is offline   Reply With Quote
Old 11-16-2008, 01:12 PM   #10
TNation
anyone figure out the problem here?
Old 11-16-2008, 01:31 PM   #11
spoony_prelude
Eurowerke
spoony_prelude's Avatar
Hey guys mine is doing the same thing! Ill drive for a little while ( say 10mins) and the needle will shoot into the red zone. 2mins later it'll just drop back to normal. I did a fan delete when I put the M in my car so not sure whats happening, im thinking thermostat is sticking, cluster is going crazy, electric fan switch isnt functioning properly?
1986 bmw 325e
1996 bmw 328i M-swapped
2012 Ram 1500 sport
2014 Honda Accord Sport
2007 Suzuki Gsx-R
2015 M109R Boss
Time for another bmw....
Old 11-19-2008, 10:15 AM   #12
champ0202
resolved!
Over the weekend I ended up replacing the thermostat and replacing the coolant I also purchased the coolant temp sensor, The thermostat was the issue it was sticking open, (post on thermostat was all marked up were the thermostat would stick open) I never did replace the coolant temp sensor. i have driven approximatly 30km and it has not overheated yet! thanks for all the advice
