Old 10-28-2008, 07:29 PM   #1
sicilianace
E-thirtysexer
sicilianace's Avatar
Send a message via ICQ to sicilianace
low beam failure on my stock headlights\\\\\\\\\\
Guys, i, previously had a hid kit installed on the car which threw off the low beam failure on the obc but now i'v gone back to stock headlights, change the fuse back to 7.5 and when i turn on the low beams, the damn obc spits out the low beam failure... ??????
......ive tried two set of low beam bulbs both work fine but why the low beam failure at the obc
need your help
e30 m3
e36 coupe
sicilianace is offline   Reply With Quote
Old 10-28-2008, 08:01 PM   #2
bmwe36_5spd
I actually have the same problem, however, my switch doesn't work(i can't switch back and forth from Low beam to night driving lights.). So, I would like this answer to be solved with regards to the low beam problem, so i can mark off one of the many dumb problems on my car.
________________________
bmwe36_5spd is offline   Reply With Quote
