Old 06-29-2008, 11:37 PM   #16
My junky open 3.73 diffy out back does more less what I said. Tryed it this afternoon. It was a bit hard to turn, I guess its about seized up (high mileage and sitting outside w/o seals and plugs since '04) the one side turned, the other stayed put. I could barely turn it, so I guess not a good example. Whatever, its a diff, and I'm not gonna fight on it/waste my time over it. That would be too childish.
Old 06-30-2008, 06:13 AM   #17
bimmer.rob
So I can take a Ti diff from a e36 ? Because my diff and tranny are noisy so im trying to figure out what i can do...would the tranny of the 1987 e work? or the gears just way to low?
bimmer.rob is offline   Reply With Quote
Old 06-30-2008, 07:56 PM   #18
Yes the Ti diff should bolt right in. Everything should bolt up too. The 325e and 325I trannys have the same gear ratios so it be the same. As for the diff ratio of the Ti, I am not sure. Ask Eurostyle, he should know. I would guess it would be around 3.91 or something high-ish like that.
Old 07-12-2008, 11:17 PM   #19
racer-x
Get one from an auto 318ti..... 4.44..... woo-hooooooooooooo
racer-x is offline   Reply With Quote
Old 07-12-2008, 11:30 PM   #20
I drove an S52 swapped car with 4.44 (before new lower ratio diff was installed) and it's insane...wont go past 160Km/h, and it brakes loose in 3rd gear, goin 80...
Old 07-12-2008, 11:56 PM   #21
TopSpeed
TopSpeed's Avatar
I have a 4.10 LSD if you're looking for something with that ratio. It's off a 160km 1991 318is
TopSpeed is offline   Reply With Quote
Old 07-14-2008, 04:52 PM   #22
FuryriderX
cra.iX.y
FuryriderX's Avatar
just to clear up any further misunderstanding:
LSD: turn one of the OUTPUT shafts, and the other output shaft turns the SAME WAY
OPEN: turn one of the OUTPUT shafts, and the other output shaft turns the OPPOSITE WAY
if the diff is old/semi-siezed, all bets are off though.
Old 07-21-2008, 01:51 AM   #23
^^^I think the "misundertanding" is what happens when you turn the INPUT shaft!
Old 07-21-2008, 04:18 AM   #24
^^lsd = both wheels spin (always)
open diff = both wheels sometimes spin, sometimes only 1. (only one wheel will have power, but sometimes the other wheel will still spin forward, just without any force.)
