07-07-2008, 03:31 PM
#16
Car: e46 M3
Originally Posted by BigD
JFYI my crappy tire fuel hoses say 12 bar.
Good stuff...guess they changed them since I last checked.
07-07-2008, 04:14 PM
#17
Car: 318T
so for my brake line repair it's like a 2 inch bad section and I dont want to replace the whole line... can I flare the line and use rubber hose rated for brake line use and just double clamp? or do do I need to use presure fitings?
07-07-2008, 06:57 PM
#18
Car: e46 M3
I don't think hose clamps will do for a brake line, you'll want to put a proper 'AN' fitting on.
07-07-2008, 07:31 PM
#19
Car: 318T
decided Im going to replace the whole line... I took a good look at everything and it's actulay much easyer then I thought it would be ... all the lines are clearly visible surprizingly... I bet it's not like that on the 540 haha
07-07-2008, 11:15 PM
#20
Car: '00 540i
Keep practicing Barry...I'm gonna pay you in car parts to start working on mine!
93 325is - sold!
2000 540ia- sold!
07-08-2008, 08:32 AM
#21
Car: e46 M3
Yeah it is. They're all visible. Most cars have them out in the open like that.
07-08-2008, 08:35 AM
#22
Car: 318T
oh well then ... I'm sure that would be the last thing to go on your car anyway
07-08-2008, 08:37 AM
#23
Car: 318T
yup im getng prity good with the e36... I just have to remember to titghten all the bolts up while swet is driping in my eyes
07-08-2008, 08:40 AM
#24
Car: e46 M3
Yeah, instead it's just repetitive power steering pump and cooling system breakage
07-08-2008, 10:14 AM
#25
Car: 08 Civic
I don't know man... I'd go full lines, not rubber ones, after what happened with the ford and my super rubber line... never again. If you install all that stuff by yourself, spend the money on the steel lines... And the bunder is around $15 at CT, you can do 4 different sizes.. My buddy did his fuel(all of them) and rear brake lines.. with the bender and some line..
I agree with Joey, keep practising, cause I'm starting to smell gas....
11-14-2008, 09:27 AM
#26
Car: 325IX
Yes, newb bringing this from the dead....
I just re-did the fuel lines on my e30, I bought the lines from Otto's, think it came out to $80 for the feed and return lines...
Relatively simple install, had a hard time undoing the old line where they were rusted, but that was the hardest part. Suggest anybody looking at redoing their lines to take a look at the oem kit. probably a little more money than flaring your own, but its was a straight bolt in procedure, worked out great
11-14-2008, 11:06 AM
#27
Car: e30 with e91 beater
Were they already bent?
11-14-2008, 11:44 AM
#28
Car: 325IX
Yup...like I said, it was a direct bolt in. Take old ones out, put new ones in, voila, new fuel lines.
EDIT: All i did was look up the part #'s on realoem.com and gave those to the parts guy at Otto's.
11-14-2008, 12:02 PM
#29
I only ask because brake lines are straight, not pre-bent, so I assumed they'd be the same. Good info, thanks!
11-14-2008, 12:36 PM
#30
Car: 325IX
Im not sure if they sell the same kind of kit for the brakelines...Im due though...I can be the test mule! Yay!
