Old 06-04-2008, 04:27 PM   #1
Jonas007
Maintenance at 100,000kms?
So my wife's 03 E46 is about to hit 100,000 kms...what should I do to it?
I'm assuming air filter (and obviously continued oil changes), but what else should be replaced as preventative maintenance now...plugs, wires, anything of that sort?
08' BMW M5, 05' Benz CLK320
Jonas007 is offline   Reply With Quote
Old 06-04-2008, 05:09 PM   #2
ImolaZHP
ImolaZHP's Avatar
Inspection 2 is at 100,000km
Here's what they do:
Inspection II
The Inspection 2 Service is the larger of the two Inspection Services and basically includes all of the items performed on the Inspection I Service along with some extras like differential oil change; fuel filter and air filter replacements; Replacement of spark plugs. Inspection 2 generally runs around $400+ to $500+. Below are the items that are normally performed. If you are performing the inspection yourself, We carry most of the BMW parts you need to complete the inspection and replacement of BMW parts. Click here for the Online BMW Parts Catalog. Don't forget to purchase the BMW service/oil change reset tool.
Undercarriage
Change engine oil and filter oil while engine is at normal operation temperature.
Check transmission for leaks.
Check rear axle for leaks.
Visually check fuel tank, lines, and connections for leaks.
Check condition, position, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks.
Check overall thickness of front and rear disc brake pads.
Examine brake disc surfaces.
Clean brake pad contact points in calipers.
Grease wheel center hubs.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
Check front control arm bushing for wear.
Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
Check for free movement of the parking brake cables. Adjust parking brake if necessary.
Check all tire pressures (including spare). Correct if necessary.
Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Check thickness of parking brake linings.
Half-shafts; check for leaks at flexible boots.
Inspect entire body according to terms of rust prevention limited warranty.
Engine Compartment
Read out diagnostic system
Check engine cooling system/heater hose connections for leaks.
Check coolant level and antifreeze protection level; add coolant if necessary.
Check level of brake and clutch fluid in reservoir; add fluid if required.
Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
Check air conditioner for operation.
Reset Service Indicator.
Replace spark plugs.
Replace intake air cleaner element.
Body/Electrical Equipment
Check battery electrolyte level and add distilled water if required.
Perform batter load test.
Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check wiper and washer system(s); wiper blades, washer jet positions.
Check condition and function of safety belts.
Oil hood, trunk/tailgate, and door hinges.
Grease hood, trunk/tailgate and door latches. Check operation of all latches.
Check central locking/double lock.
Replace microfilter or Acc Cabin Filter.
Check heater/air conditioner blower, rear window defogger.
Check rear view mirrors
Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
ImolaZHP is offline   Reply With Quote
Old 06-04-2008, 10:05 PM   #3
Jonas007
Thanks, sounds easy enough.
Where's the cheapest CDN place to buy the spark plugs, and which model are they? Same goes for the filter, and what about the in-cabin filter, where is it, as I've never replaced one on any of the cars I've owned.
Old 06-05-2008, 04:32 PM   #4
Jonas007
nevermind, got some today with the recommended part, the NGK BP6 BQUS or whatever they're called...$11 each for the rip-off plugs.
Thanks.
Old 06-13-2008, 11:29 PM   #5
hackman
where did u get 400 to 500 i taught inspection 2 costs around $1000
Inspection II
Undercarriage
Engine Compartment
Final Inspection
hackman is offline   Reply With Quote
Old 06-16-2008, 01:10 AM   #6
ImolaZHP
ImolaZHP's Avatar
That's from an American website.
Old 06-16-2008, 11:32 AM   #7
JNSchnitzer
Christ is King
JNSchnitzer's Avatar
Go to Bimmersport Automotive (phone: 905-670-9200 , web: http://www.bimmersport.ca/). They do it for way cheaper than $1,000, I'm not sure what's their current price as they may have summer deals.
JNSchnitzer is offline   Reply With Quote
Old 06-16-2008, 06:50 PM   #8
BmW1819
around 900 - 1100
Old 06-22-2008, 08:02 AM   #9
Airbalancer
Inspection 2 at autobaun east is $499 autobahneast.ca
Airbalancer is offline   Reply With Quote
Old 06-28-2008, 06:57 PM   #10
Alizay
Bad Man Wagon
I think Bimmersport charges something like $450-$500 for Inspection II.
---My Ride---
2003 BMW 330i M-Package (E46)
LOOKING FOR:
Smoked Tail Lights, Corners and Side Markers for my 2003 BMW 330i
BMW = Bad Man Wagon!!!
Alizay is offline   Reply With Quote
