Originally Posted by againstallodds
how much do the stock 328 fuel injectors give out? and is there any that i can get from another car/motor that are compatible to use for the boost?
you can use Ford green tops
what kind of manifold should i use? and is there one compatible to use from another car/motor to the 328?
depends on what you want. there are lots of log style manifolds on the market which are a lot more affordable or you could go with a custom or mass produced custom like 666 which make top mount and bottom mount tube style
computer tunning? is there an air fuel hack system i can get?.
lots of options here, you can either reprogram your current ECU or go with the many choices of piggybacks and standalones, (i.e-megasquirt, tec3, AEM)
and lastly, where can i get a wideband o2 sensor?
pretty much anywhere local i got my older AEM from ebay (thanks sickfinga) but you can get those here at local performance shops.
