Old 04-09-2008, 01:02 PM   #1
ara_yaz
Bimmer Fan
ara_yaz's Avatar
Removing Badge
Hi guys, i'd like to remove the "325 iS" badge off my trunk. I had the trunk repainted about 1 month ago (i was rear-ended) so the paint is relatively new and i'm not really worried about colour-fading underneath/around the badge area once it's removed (or should i be concerned about this?).
What's my best way to do this without causing any damage?
Any help would be appreciated.
Thanks,
Ara
ethirty
ara_yaz is offline   Reply With Quote
Old 04-09-2008, 01:44 PM   #2
NateoriouS
Nateorious C.A.G
NateoriouS's Avatar
use a heat gun to heat up the adhesive on the back.. about 2 minutes or so
use the heat gun in a left to right waving motion... so that the heat isn't concentrated on one spot for too long...
then while it's warm... use either fishing line.. or dental floss .l both work great.. and in a sawing motion.. work your way behind the badge..! until it's off... sometimes you'll need to reheat and then "saw" again..!!
after all is said and done... use "goo gone" to remove remaining adhesive... and a paper towel.... .. if you don't have goo gone... cooking oil works great too...
good luck
p.s. it's very easy..!!
'88 E30 325i sold
'88 E30 325i 2.7 stroker sold
'95 E36 318i sold
'94 E36 325ic Cabriolet sold
'87 Mazda RX-7 Turbo II sold
'96 E36 328i Cabriolet - sold
'92 Mazda Miata Black Nardi Edition sold
'98 E36 M3 Cabriolet -
"Float like a Cadillac, Sting like a BEAMER" ... ... Lightning McQueen
NateoriouS is offline   Reply With Quote
Old 04-09-2008, 08:21 PM   #3
HoldenC
Pro Mobile Detailing
No heat gun is necessary as it can destroy paint and possibly the body of the vehicle in mere seconds. Other than that, you may use fishing line and patience. Goo Gone is a suitable OTC product, but I prefer the professional line products such as Dupont Wax Remover (I forget the exact name now). Any kind of solvent will work, though.
HoldenC is offline   Reply With Quote
Old 04-09-2008, 11:36 PM   #4
Allstar_e36
Allstar_e36's Avatar
Here's the link i used, and it worked out pretty well.
http://www.e46fanatics.com/howto/how...php?howto_id=1
gl
Allstar_e36 is offline   Reply With Quote
Old 04-09-2008, 11:52 PM   #5
slemmer
Driving in the fast lane
slemmer's Avatar
WD-40 works good with dental floss (mint flavour)...smells good while working the adhesive off.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 04-10-2008, 12:10 AM   #6
///MG
///MG's Avatar
make sure it's the mint flavoured one!
2003 BMW 330CiC CURRENT
1996 Toyota Camry FOR SALE
1998 BMW M3 IN EUROPE
2004 Mitsubishi Galant SOLD
1993 Plymouth Duster SOLD
///MG is offline   Reply With Quote
Old 04-10-2008, 10:16 AM   #7
Michel
Michel's Avatar
dental floss + bug&tar remover for the adhesive.
Michel is offline   Reply With Quote
Old 04-10-2008, 11:50 AM   #8
europrince
what if someone doesn't like mint??
Old 04-10-2008, 11:55 AM   #9
Sa///M3
Sa///M3's Avatar
Who doesn't like mint?!
"Circumstances may cause interruptions and delays, but never lose sight of your goal"
-Mario Andretti
Sa///M3 is offline   Reply With Quote
Old 04-10-2008, 01:01 PM   #10
ara_yaz
Bimmer Fan
ara_yaz's Avatar
thx guys...I appreciate the help!
ethirty
Old 04-10-2008, 05:16 PM   #11
slemmer
slemmer's Avatar
Dual purpose - after you debadge, chew it and it'll clean and freshen your breath (if you use mint)
'04 645cic
'00 740i Sport
