Old 02-25-2002, 09:34 PM   #1
ryee
Send a message via ICQ to ryee Send a message via AIM to ryee
Clutch problem?
I've been noticing this for quite a while, but when I disengage the clutch... everything is ok, but when im at idle and the clutch is engaged and im in neutral, there is a rattling noise coming from underneath the car.... What could this possibly be?
ryee is offline   Reply With Quote
Old 02-25-2002, 09:55 PM   #2
SWHEEEET
SWHEEEET's Avatar
My first guess would be a lose muffler and that is causing the rattling noise. Unless someone gets under the car (hopefully not when you are driving) to check it out....
1998 328i
How SWHEEEET is that
SWHEEEET is offline   Reply With Quote
Old 02-25-2002, 11:18 PM   #3
mike125k
Send a message via AIM to mike125k
i believe this is a relatively normal thing to happen on E30s.
1991 318is aka: the torque-less wonder!
mods: TSW Hockenheims, H&R springs, Bilstein shocks, Supersprint exhaust, Jim Conforti chip, K&N, Z3 short shifter conversion, custom made strut tower brace
1988 Ford Ranger STX
mike125k is offline   Reply With Quote
Old 03-02-2002, 08:00 PM   #4
matt325is
Send a message via AIM to matt325is
My uncle (car mechanic) said that it could be the sign of a bad transmission bearing. My car does the same, when the clutch is out, it rattles, but when pressed in, it goes away. It would make sense that it is the bearing, the clutch disengages the transmission from the engine.
Now if your clutch is out, and it doesnt rattle, but when it is in, and rattles, then it is your throw-out bearing.
matt
matt325is is offline   Reply With Quote
Old 03-03-2002, 03:02 AM   #5
S50_boy
i had the same problem...i changed my throw out bearing and i still had it...it was my pilot bearing.... drop the tranny change your throw out bearing and the pilot bearing at the same time...i beleve you need a special tool to change the pilot bearing....
S50_boy is offline   Reply With Quote
Old 03-03-2002, 03:54 AM   #6
Bliss
Administrator
I'm also pretty sure its the clutch bearing.
For maxbimmer decals, and t-shirts, email info@maxbimmer.com
Old 03-04-2002, 08:27 PM   #7
Furious
BMW again.
Furious's Avatar
i agree.
i think its the clutch berring,, may just be worn a bit,, i had the same problem on the old civic,
