10-22-2007, 05:56 PM
#526
Car: E30 325i
Is it also a great fit for the car? You mention earlier that some fender rolling is required, would I be better to run 205?
Thx, Rob.
10-22-2007, 08:27 PM
#527
E30 M20
Car: 1987 325i
Hi Jay,
Would you know where I can buy some hub-centric rings (57.1mm) for my Kosei K in the GTA? Need them pretty fast.
Thank you!
10-22-2007, 09:48 PM
#528
Car: S54
Thx, Rob.
With 205/45/17 tires you will be 100% safe. With 215/40/17 tires, if the tires run wide and you have a very soft springs (which you don't, they're pretty medium) you may rub on the rear over huge bumps. Honestly don't worry about it, 215's are a better fit on the 7.5" rim anyways.
10-22-2007, 09:50 PM
#529
Car: S54
Originally Posted by Gleb
Hi Jay,
Thank you!
Wheels Direct has the biggest supply of rings I've seen.
10-23-2007, 10:30 AM
#530
Car: E30 325i
Awesome man, You've been a great help. Now to find the brand and kind of tire.
10-23-2007, 01:07 PM
#531
E30 M20
Car: 1987 325i
Thank you, would you happen to know the bore size of the Kosei K-1 15x7 wheels?
Thanks again!
10-29-2007, 11:18 AM
#532
The Afro-stig
Car: Is Fast. ;)
Yoes Jay, I think im due for a new set of tires for my Remembers this spring comming up. Do the Falken 512's come in in 215/45/16 and will i be able to run them with them lower rear arches???
10-29-2007, 12:10 PM
#533
Car: S54
Nope, no 512 (or 912) in 215/45/16. The RT-615 is though, and yeah it will just fit without rubbing. I think your wheels will look better with that size too.
11-13-2007, 10:57 AM
#534
Car: 91 325i coupe
HRE 18x7.5 3pc ET38.
18x7.5 et38 HRE3pc off an early 1600/02 w4x100.wanli215/35/18.To go on my 91' 325i Coupe lowered with H&R springs and Bilstien Sport.Please could you advise on what I'll need to do.They are not in my posession yet.
11-13-2007, 06:56 PM
#535
Car: S54
Those should actually bolt right on without any work, but please if they're HRE's get some 15mm spacers to bring them out to the fenders nicely. They won't rub with that size spacer.
11-13-2007, 11:32 PM
#536
Car: God's Chariot
I doubt those rims would fit an '02 anyways. It would hit the front strut with a size and offset like that.
11-14-2007, 08:50 AM
#537
Car: 91 325i coupe
Awesome!Any recommendations as to what type of 15mm spacers and lug bolts and supply source would be greatly appreciated.I believe the rims are HRE Comp 20's.The previous owner had them on a '68 1600.
11-14-2007, 08:06 PM
#538
Car: S54
H&R.
12-25-2007, 12:31 PM
#539
Car: s52 88' 325i touring
Have an early arch e30 with an H&R sport suspension kit dropped 1.3 inches I believe (not installed by me). The wheels I'm interested in are DZ Exklusiv DZ1's. An obvious choice would be the 16x9s at they look great on our cars but I'm curious if I could squeeze 17x8.5 in there. Obviously I'd have to roll the fenders but could I fit them with the proper tire? Available offsets are et 15 and 30
12-25-2007, 01:38 PM
#540
Car: S54/E36
17X8.5ET15 will fit all around. U will definitely have the roll the rears just a bit. as for tire size, go with 215/40's.s
u know those wheels comes in 10X17?
