Old 10-12-2007, 08:06 PM   #1
320ie36
320ie36's Avatar
my heat dont work need help
my car heater only works on number 4 but no hot air comes out but the ac is fine but still only works on 4 whats has happend
320ie36 is offline   Reply With Quote
Old 10-12-2007, 08:29 PM   #2
For the only position 4 issue, blower motor resistor. Around $80 at the dealer, pretty easy swap.
As for no heat, that's a bigger issue.
Old 10-12-2007, 10:56 PM   #3
320ie36
320ie36's Avatar
like what
Old 10-12-2007, 11:25 PM   #4
carjoe
carjoe's Avatar
Clogged heater core, broken heater valve, clogged cabin filter, busted thermostat...
93 325is - sold!
2000 540ia- sold!
Old 10-13-2007, 03:04 AM   #5
Eurostyle
Eurostyle's Avatar
Resistor...for the 4 part, i got one used for $20 works on all 4.
The rest can be many things, headgasket beeing the most common one...(will get air in your cooling system, and the heater core will be empty and cold)
Old 10-13-2007, 10:00 AM   #6
NateoriouS
Nateorious C.A.G
NateoriouS's Avatar
^^^trying to sell the resistor you said you'd hold for me?? heheh
'88 E30 325i sold
'88 E30 325i 2.7 stroker sold
'95 E36 318i sold
'94 E36 325ic Cabriolet SOLD
'87 Mazda RX-7 Turbo II sold
'96 E36 328i Cabriolet - sold
'98 E36 M3 Cabriolet -
"Float like a Cadillac, Sting like a BEAMER" ... ... Lightning McQueen
NateoriouS is online now   Reply With Quote
Old 10-13-2007, 03:21 PM   #7
archrival
E36 Addict
archrival's Avatar
First thing to check would be your coolant level if you are not getting heat....if its low top it up...then if it goes down you have a problem..some of which are mentioned above..a clogged heater core can be a major one...you can flush it out by taking both lines off and putting a hose on one end and blowing water through it and then reversing the process..do this a few times and you can usually blow most of the junk out of it.
Old 10-14-2007, 01:07 AM   #8
Eurostyle
Eurostyle's Avatar
lol I can only hold it for so long!
Old 10-14-2007, 02:49 AM   #9
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
how about A dead fan??
i got nothing .. it's done it intermittently before..
but its been off for a few weeks now.
Old 10-14-2007, 03:03 AM   #10
Eurostyle
Eurostyle's Avatar
Are you asking a guestion, or suggesting a solution
Old 10-14-2007, 02:50 PM   #11
bmdbley'sBro
sorry a question....
what causes a dead fan ? all fuses are good.
it would die then come back for a few weeks, then die..
it hasn't worked in a few weeks now.
