Old 09-14-2007, 01:42 PM   #16
Furious
BMW again.
Furious's Avatar
Originally Posted by Flav_cool View Post
Yea. so AFR wouldn't be found on emissions test eh?
no your talking Lean/Rich values, emmision are based on these values but arent the same.
Old 09-14-2007, 01:47 PM   #17
JUICY J CAN'T
propr'one's Avatar
Well, i think the E-test does give you an afr at 2000RPM or something but you're looking for consistancy during the RPM range. Get a dyno done. Dont worry about the chip, your car has knock sensors, it will retard the timing if need be.
hid headlights
Old 09-14-2007, 01:52 PM   #18
Dr. Flyview
Formerly Flav_cool
Dr. Flyview's Avatar
Isn't that if you use octane that's too low? How would that help too lean a mixture?
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
sold
Old 09-14-2007, 01:55 PM   #19
JUICY J CAN'T
propr'one's Avatar
just running a motor too lean can, and will eventually damage it even without knocking. But just for a reference point for you.
My motor is a m52b28, pretty much stock. I'm running s52b32 software on it (litterally, took the chip out of a M3, put it in my car, no tuning).
Because of things like the Maf, CPS, O2 sensors, etc, your chip makes sure its running correctly. You can usually tell a poorly tuned car very quickly. Like mark has said, dont worry about it, put the chip in (assuming its for the correct motor (vanon vs-non vanos) and enjoy.
hid headlights
Old 09-14-2007, 02:38 PM   #20
NOTORIOUS VR
NOTORIOUS VR's Avatar
although there is always a risk when changing the engine management... the other thing is, do you know if your fuel injectors are good? hows the spray pattern? do they all flow the proper amount and within a specific % of each other? All these things become more dramatic when you modify something.
E36 · VEMS · TUNING
Google Talk: NOTORIOUS VR
