09-13-2007, 09:02 PM
"Mint"
Car: '98 328is + '93 525i
Performance chip leaning out engines
Hi,
I have heard people say performance chips (I have a MarkD) can lean out the engine too much and cause the valves to burn. A month after I put it into my non-vanos engine I had a hole in my valve (not saying it was because of the chip, but it DID happen). Replaced that motor with a vanos, and ran a chip again another 4 or so months no problems (till I crashed into a tree).
Now I have a new car and am debating putting in the chip or not. Should I check my A/F ratio before I put it in to make sure it's not already close to lean? Would this information be on my emissions test sheet?
Thanks,
Flaviu
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
1988 Mercedes Benz 190E 2.3-8V - sold
09-13-2007, 09:42 PM
Imaginary Player
Car: YZF-R6, F30, e36
What car did you pick up
Yamaha R6 + Alpine White F30 + Techno Violet e36
09-13-2007, 09:45 PM
"Mint"
7/94 325i 5spd sports package, 160k.
09-13-2007, 10:33 PM
Car: God's Chariot
Just don't buy a Dinan chip. That is all.
09-13-2007, 10:34 PM
"Mint"
?? C'mon guys explain a little. I've got a MarkD chip.
09-13-2007, 10:56 PM
BMW again.
Car: 1994 325is
nothing wrong with dropping 50 bucks for a run on the dyno to see where your ballparking after a few mods. chips typically lean the car out because the lean side is the powerful side, however the trade off is your flirting with a dangerous situation where if you lean out too far , bye bye engine. short of that, you will really never quite know what is the actual issue at hand.
09-13-2007, 11:08 PM
Car: God's Chariot
Thats pretty much all that the Dinan chips do. They just lean the shit out of the engine timing and it obviously produces major detonation.
I have seen a Dinan, Conforti(TMS also I believe) and MarkD chips back to back for an e30 M3. The Dinan was by far the worst. The Conforti and the MarkD chips were similar, but the MarkD chip had a bit of an edge over the Conforti.
09-14-2007, 12:25 AM
BMW again.
Car: 1994 325is
ive heard that the only good chip dinan makes is for the 318's but its only something i heard. i have no clue, i had a markd chip in my 325 when i had that engine and she ran the car beautifully
09-14-2007, 12:18 PM
AMG ETR
Car: S/C S54B32
whats the wtf in your sig suppose to be??
09-14-2007, 12:29 PM
#10
Car: E46 M3, YZF-R6
^^that's julian.
The AFR's from mark's chips i've seen are pretty much 12-12.5 right across the board, which is pretty much perfect. If you trust the tuner, you dont even have to get an AFR unless you have reason to believe something is wrong.
Having said that, as mark said, a 2-3 pulls on a dyno is like 50-60 bucks, with AFR, if you're worried about a car, dyno it.
09-14-2007, 01:16 PM
#11
BMW again.
Car: 1994 325is
thats me, my car, slovaniaboy and his car, last years bimmercruise. if you look closely you can see julian (Gamite) in the background giving us the finger.
pretty funny actually..
Proprone is correct markd's chips are pretty spot on, id look into other possible issues for your leaning out issue.
09-14-2007, 01:18 PM
#12
"Mint"
Well I have no idea if the new car is running lean but if it is b/c of some other problem and I put in the chip I'm ****ed...just don't know if I should take the chance.
09-14-2007, 01:19 PM
#13
BMW again.
Car: 1994 325is
dyno the car with AFR
/end until you get the results
09-14-2007, 01:20 PM
#14
Car: M3
did you use premium gas when you had the chip at all times?
09-14-2007, 01:37 PM
#15
"Mint"
Yea. so AFR wouldn't be found on emissions test eh?
Thread Tools |
Display Modes |
