maXbimmer Forums
maXbimmer Forums (http://www.maxbimmer.com/forums/index.php)
-   Audio/Sound (http://www.maxbimmer.com/forums/forumdisplay.php?f=35)
-   -   Fosgate amp questions (http://www.maxbimmer.com/forums/showthread.php?t=88643)
BlitzSix 04-15-2007 04:31 PM
I recently aquired a fosgate T4004 amp, and some alpine type S speakers, pictured below:
http://www.nastysix.com/bs/IMG00163.jpg
http://www.nastysix.com/bs/IMG00164.jpg
If one was to read the specs, they would see that this amp is rated at 25 RMS x 4 @ 4 ohm.
The alpines are rated at 2-50 RMS @ 4 ohm. So the amp would push them at 25 RMS, which is good (not underpowering or overpowering them).
Here are the specs:
http://www.nastysix.com/bs/IMG00171.jpg
As you can see, 25 RMS per channel on 4 ohm.
But, as you observe the birth sheet, it says 91 RMS x 4 at 4 ohm!
http://www.nastysix.com/bs/IMG00173.jpg
Can someone explain to me how this works? Why does it show that my amp is putting out almost 4 times teh power it's supposed to put out? Am I reading the wrong or something? Why would fosgate do this? Is this amp too powerful for my speaker now?
Please help :(
Also, why does it say 55.842% effieciency? What does this mean? Does it mean my amp sucks?
Thanks.
FuryriderX 04-15-2007 05:58 PM
no, not a chance. your amp is just underrated. consider this a good thing. most are overrated.
Mystikal 04-16-2007 01:50 PM
haha, awesome.
91rms is a lot safer than 25rms. Enjoy the significantly better sound (if it was actually 25rms I wouldn't even want to run it).
T.Dot_E30 04-16-2007 02:02 PM
Its actually a good thing, jus dont turn ur gains all the way up.
BlitzSix 04-16-2007 04:19 PM
Thanks guys. I won't turn them all the way up :)
Jay... can you explain please? How is running the speakers at an RMS that's almost twice the maximum safer than running then them within their range?
Mystikal 04-16-2007 04:58 PM
25rms is low. Extremely low.
Speakers sound better given more power (same other variables). It's actually 10x safer to run an amp with a lot more power than the speaker than vice versa (or even running just 25rms). This is because the speaker will distort audibly before the amp clips. And the vast majority of the time, it's amp clipping which damages drivers.
BlitzSix 04-16-2007 11:26 PM
That sounds logical, but why would the amp clip if its running within the required RMS.
Would you consider this amp good to push these speakers? Are these speakers good?
Is it okay if I use a Memphis amp which pushes out 1100 RMS to power 2 fosgate power 10s that are rated at 150-600 rms each ? So 550 to each sub?
FuryriderX 04-17-2007 08:35 AM
the amp clips when its driven past its specs. notice on the spec sheet its stated '91rms @ <1%THD' - this is the distortion spec. they didnt get that value by maxing the gains. any amp will distort if you push it too hard.
yes, the amp is perfect for those speakers. sounds pretty decent.
and yes, you can use that amp on the subs. i used a 1500wrms amp to power 2 subs rated at 350 apiece :D havent blown them up yet
T.Dot_E30 04-17-2007 09:33 AM
Just use your ears or have your system tuned properly.
Don't just turn everything up and expect it to sound good.
Mystikal 04-17-2007 11:34 AM
The amp will clip if the volume is too high. And if the amp isn't as capable as the speakers, you won't have much audible warning; by the time you hear clipping it might be too late. On the contrary, if the amp is better than the speakers the drivers will just distort, which gives you a nice reminder to calm down on the volume.
That amp sounds good, and the speakers are decent too. As long as you have a good headunit and tune it all properly, that should be a great sounding system.
The Memphis amp, is it 1100rms into 2ohms? And what is the impedance of the subs?
Axxe 04-17-2007 01:21 PM
Overpowering >> underpowering. You can always turn the gain down.
BlitzSix 04-17-2007 04:19 PM
Uhh the Memphis amp is 1100 RMS at 1 ohm. And it's 1 ohm stable. And okay I found this part confusing but my audio guy assured me it makes sense: The subs are dual 4 ohm coils, which somehow makes each one run at 2 ohms which somehow makes them run together at 1 ohm when you connect them in parallel, thus being good for the amp. Does this make sense? He told me to go with the T110D4 isntead of the T110D2 because with the d4 i can run them at 1 ohm or something.
http://akamaipix.crutchfield.com/pro...5T110D4-b.jpeg
http://akamaipix.crutchfield.com/pro...5T110D4-f.jpeg
T.Dot_E30 04-17-2007 05:07 PM
1 Attachment(s)
he is right.
Two DVC 4ohms sub could be wired up to run at either a 4ohm or 1ohm load.
See below.
The reason the 1ohm load is X-out is bcus the amp i took this from isn't 1ohm stable, but urs is.
BlitzSix 04-18-2007 12:03 PM
Doesn't the protect mode turn on if too much load is on it?
PS THanks t dot.
