maXbimmer Forums
maXbimmer Forums (http://www.maxbimmer.com/forums/index.php)
-   5 series (http://www.maxbimmer.com/forums/forumdisplay.php?f=61)
-   -   91 e34 obc ignition lock out? Reset? (http://www.maxbimmer.com/forums/showthread.php?t=155420)
civic_eater 01-23-2013 01:02 PM
So my friend just bought his first bmw a 91 e34. Car ran great and it had an ignition lock code set on the obc that was 0000. My buddy being a noob changed the code and then forgot it..... How do i reset this security system?now the car wont start without the right code
bmwm5lover 01-23-2013 03:16 PM
no clue....did you try to disconnect the battery overnight? will that even help?
MANDD 01-23-2013 03:44 PM
The 91 E34 uses OBC 4. To deactivate this in the event the code is forgotten do the following;
1. Disconnect and then reconnect the battery
2. Turn ignition to position 1 only. (the horn may/will sound)
3. The OBC will now display a time of 15:00 minutes, this will now count down.
4. After the 15:00 minutes has elapsed the car may be started.
Mark.
civic_eater 01-23-2013 07:33 PM
Will it do that everytime or can i reset the code?
TSI 01-23-2013 08:30 PM
You can reset the code. Once you start the engine the code is erased.
