maXbimmer Forums
maXbimmer Forums (http://www.maxbimmer.com/forums/index.php)
-   General Discussion (http://www.maxbimmer.com/forums/forumdisplay.php?f=2)
-   -   E36 18 Button Conversion HELP (http://www.maxbimmer.com/forums/showthread.php?t=126524)
e30bim 10-24-2009 05:40 PM
I did the conversion almost about a year ago and entire computer has worked perfectly. The only part I did not have was the turn stalk to control the computer from the steering wheel. When I did the conversion I ran a wire to the steering wheel area for when I finally got it. Last weekend I got the stalk and crimped the wire I ran to the brown/red as the instructions on #7 state:
7. Install the turn signal stalk. Tap into the brown/red wire of the new turn signal stalk and run it to the brown/red wire of Pin 4 of X1071.
I did this and it is not controlling the computer at all. I know there is someone on here who has done multiple installs regarding this and I'm hoping I can get some help. When I crimped the new wire into the brown/red I ran an "in-line" crimp that allows the brown/red and the brown wire to allow its normal function. Should I have just cut it at the turn stalk and not plugged that connector back in?
Can someone help and be extremely specific on the OBC turn stalk portion please?
Thanks!
e30bim 10-24-2009 05:50 PM
Found the answer. Tap into Yellow/Red on the turn stalk not brown/red as pellican article states.
